Is it VTEC?
Is it VTEC?
i'm still a lil bit new to the whole sport compact thing, but in my '96 HX there's supposed to be a D16 SOHC Vtec-e. A guy i know looked at the motor and said it's not VTEC bcuz it'll say it very small on the valve cover. another said it IS because it has some valve/senor thing that only VTECs have. How do I know?
Re: Is it VTEC? (SprayinCX)
yes the VTEC solenoid should be a connector on the side of the cylendar head with a green plug on it. Maybe someone has a pic for you to see.
Former Moderator
Re: Is it VTEC? (DreD16)
Look at the block code located (if facing the engine from the front of the car) just to the left of the header. If it says D16Y5 then it is the stock HX engine, which is a 115hp VTEC-E regardless of what the valvecover does or doesn't say.
1992-1993 and 1996-2000 SOHC VTEC engines do NOT say VTEC on them. Only 1994-1995 ones did.
Re: Is it VTEC? (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">Look at the block code located (if facing the engine from the front of the car) just to the left of the header. If it says D16Y5 then it is the stock HX engine, which is a 115hp VTEC-E regardless of what the valvecover does or doesn't say.
1992-1993 and 1996-2000 SOHC VTEC engines do NOT say VTEC on them. Only 1994-1995 ones did.</TD></TR></TABLE>
my old d16z6 didn't sway VTEC!!!
not sure about the 1996-2000 cuz i don't have one and never payed attention to one when i saw one, but i agree with the 1992-1993 part, my 1993 si doesn't say it, neither does my friends 92, but my friends 95 does hahah
Re: Is it VTEC? (mRek9R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mRek9R »</TD></TR><TR><TD CLASS="quote">here you go!! 8)
Magic switch....beautiful
Just for an info (not trying to bash) it's a solenoid, switch is inside the plate that's what the green plug is for. Solenoid the big cylinder thing uses one wire.
Re: Is it VTEC? (Beaver EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beaver EJ1 »</TD></TR><TR><TD CLASS="quote">The only valve covers that say VTEC are the 94 and 95's</TD></TR></TABLE>
yes this is vtec, but its a entirely different vtec then what your probably thinking. read about it. I really dont feel like explaining it cause i dont feel like typing that much.
Re: Is it VTEC? (HXvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">
Just for an info (not trying to bash) it's a solenoid, switch is inside the plate that's what the green plug is for. Solenoid the big cylinder thing uses one wire.</TD></TR></TABLE>
Quiet with the technical mumbo jumbo. He was kidding and it was funny.
Re: (egcoupe94)
the vtec e are more fuel efficient and are slower then a normal vtec because they wanted economical over power isnt it as slow as a dx??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXvtec »</TD></TR><TR><TD CLASS="quote">yes this is vtec, but its a entirely different vtec then what your probably thinking. read about it. I really dont feel like explaining it cause i dont feel like typing that much. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exotik4doorcivic »</TD></TR><TR><TD CLASS="quote">the vtec e are more fuel efficient and are slower then a normal vtec because they wanted economical over power isnt it as slow as a dx??</TD></TR></TABLE> pretty much.
WRONG my '93 Del Sol B16Z6 said VTEC on the valve cover
