Need help installing o2 sim. in obdIIb car
hey guys, search is down so i need some help
my car is a 99 civic dx with an b16a2, so essentially its a 99 Si (SiR), i have an o2 simulator for my secondary o2, but im not sure which pinouts are for the secondary o2 signal, and i need a power, and ground signal, could u guys help me out??
Thanks!
Thanks!
so those are for the secondary o2 correct? is a8 the heater wire, and a23 the signal wire?
could also tell me a power wire and a ground wire out of those wiring schematics, thanks
Re: (menkio)
Once the search is available again.
Search for FAQ in the Archives, created by Spade
There will be a ECU pinouts thread that has engine bay wiring diagrams.
okay well i installed it, but i still have a check engine light (ecu reset) so im thinking it has something to do with the heater wires not being plugged up to anything, i think im gonna have to wire a resistor in the heater wires
Re: (BeerBaron105)
Did you ever figure it out? I just swapped a 99 b16a2 into a 99 dx hatch and need to wire up the secondary 02 sensor. I'm using the 99 si engine harness. I removed the secondar o2 sensor plug and wires from the DX engine harness. Do the pins go into the same locations in the si ecu plugs?
Dominicandude
03-10-2006 10:16 PM
