d15b swap into vx civic dizzy question.
I own a 1992 vx civic and want to buy a d15b engine for it I have just found one for sale but without a dizzy. So I am wondering do I need this dizzy for the engine swap or is the original one ok. the original engine was a 1500 vtec_e.
Thanks
Thanks
Re: d15b swap into vx civic dizzy question. (d15b)
When you say D15B, you mean the Vtec one? Anyhow, IIRC, the VX dizzy is the same as the Z6 dizzy. So... yes you can reuse your old dizzy. Someone will chime in to confirm
Re: d15b swap into vx civic dizzy question. (Cuong-nutz)
what will I need for the swap then I no i need a new ecu but can I keep all the original vx manifolds and all that other stuff.????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15b »</TD></TR><TR><TD CLASS="quote">what will I need for the swap then I no i need a new ecu but can I keep all the original vx manifolds and all that other stuff.????</TD></TR></TABLE>
I can confirm that your vx dizzy will work fine on the d15b. You can use your original vx manifolds, but I would highly recommend upgrading to a z6 or y8 intake manifold, since they can be bought for so cheap now a days. The stock vx manifold ports and plentium are tiny, and the throttle body is like 50mm, haha
Re: d15b swap into vx civic dizzy question. (xtremeazian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian »</TD></TR><TR><TD CLASS="quote">and the throttle body is like 50mm, haha</TD></TR></TABLE>
More like 35ish, horrible lol. Also, wouldn't the 5 wire o2 interfere with the swap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cuong-nutz »</TD></TR><TR><TD CLASS="quote">When you say D15B, you mean the Vtec one? Anyhow, IIRC, the VX dizzy is the same as the Z6 dizzy. So... yes you can reuse your old dizzy. Someone will chime in to confirm </TD></TR></TABLE>
Forrest Gump 9
05-25-2003 04:20 PM
