Plug wires?
Plug wires?
What do you all think of MSD plugwires. They showed that theyre only 8.5 mm whereas other companies are going a lot bigger and didnt knwo what you all recommended? Cant afford Nology so i want to go the best i can for around 50-60 bux hopefully.
Re: Plug wires? (EK_Coupe)
no ****? even with denso iridium plugs youd still say that the NGK would get the best fire? would you say if i was gonna do the ignition pack and coul to then go with msd or stick with NGM all around?
Re: Plug wires? (isumase)
Well switch out the Denso plugs for starters, go back to NGK plugs as well. I wouldn't even really worry about ignition upgrades, many high HP setups are running the stock ignition still.
