help
help
ive had my 00 civic si for like a year now... and been having a oil problem.. ever since i bought the car its been burning oil.. ive done a compression test on it and it all checked out... also i took out the pcv valve and it was done for.. so i replaced it... but still im burining it.. im guessing my problem might be my valve seals.. but enuff for a quart of oil a week?.. ruffly 400 miles a week.. ne suggestions?
Re: help (code415)
When your PCV system clogged it pur crazy pressure on your seals. Check your crank seal(rear main seal), spark plug seals, valve cover gasket, etc... Just replacing your PCV valve won't fix it, you should clean out the spot where it connects at as well as the tube running to it and then before that, with intake cleaner. That should help shed some light, if not I tried, good luck cuz.
Or is it, you love VTEC that much? j/j
1 Post
Re: help (code415)
as said above,a leakdown test should help pinpoint any consumption problem.
also don't forget to check for leaks.is there oil visible anywhwere on the outside of the engine?specifically around the oil pan?
2.A. Please do not post misleading or unspecific thread titles. Please don’t post “Help Needed” or “Look at this problem.” Make your thread titles specific to the question you are asking
Chris
Chris
G3teg96
08-20-2011 05:00 PM
