help civic turbo burning oil
my civic is burning oil very bad i have just installed a homeade turbo kit sr20 turbo intercooler fmu check eng. light bypass etc. it stops smoking when i take off charge pipe to intake manifold
when i was installing it i accidentally boosted it a couple of times over 16 psi on stock moter i have changed headgasket could it be a bad head or pistons
Re: help civic turbo burning oil (DrifteR8969)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrifteR8969 »</TD></TR><TR><TD CLASS="quote">your piston rings are probably bad, oil is getting in the combustion chamber.</TD></TR></TABLE>
That is my guess. Especially after you boosted 16 pounds on stock internals.
Re: help civic turbo burning oil (SOHC4life 96)
16 pounds on stock internals!
I would like to see a video of the cylinder walls when you hit 16psi. :wobble:
Re: help civic turbo burning oil (flood)
Your lieing and done know what the **** your talking about.
And if your not you blew up your motor, go buy a new one rich boy.
RACEPAK
11-19-2005 03:19 AM
