E-Brake Cable (HELP PLEASE!!!)
EDIT: can someone please tell me the length of 99-00 Si e-brake cables?
OR can someone tell me if DA e-brake cables with bolt up directly to the 99-00 Si rear disk brakes and fit on my 96 hatch
Okay, so I bought a set of rear disk brakes off a 99-00 Si for my 96 dx hatch and the e-brake cables have been cut. I would like to know if I must use the 99-00 SI brake cables? is there any other alternatives like integra ones and such.
Here is my watned add.
https://honda-tech.com/zerothread?id=1221562
some is willing to sell me what he believes is DA e-brake cables...i would like to know if these will work or not....and if anyones that has a set that will work for my car i would like to take it off there hands
THANKS IN ADVANCE
Modified by JDM B16 EK at 4:13 PM 4/29/2005
Modified by JDM B16 EK at 3:25 PM 5/2/2005
THANKS IN ADVANCE
Re: E-Brake Cable (137)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 137 »</TD></TR><TR><TD CLASS="quote">either si or gsr will work... you do know how to use search right. </TD></TR></TABLE>
thanks but i've tried searching but came up with nothing....
i just wanted to know if the si and gsr ones were interchangeable
or if the DA ones would work
Re: E-Brake Cable (JDM B16 EK)
you should use si ones ........... the integra ones need to have the little grommet cut up because they attach to the ebrake in one piece instead of in 2 like your civic ones.
Re: E-Brake Cable (WildPig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WildPig »</TD></TR><TR><TD CLASS="quote">you should use si ones ........... the integra ones need to have the little grommet cut up because they attach to the ebrake in one piece instead of in 2 like your civic ones.</TD></TR></TABLE>
HUH? No, I have integra e-brake cables on my 96 coupe and they work just fine. Yes the Si ones will fit better but they both work.
Re: E-Brake Cable (egsauce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsauce »</TD></TR><TR><TD CLASS="quote">get a tape measure</TD></TR></TABLE>
i would but i don't have any laying around.
it would really help if someone knew if the DA brake cables will bolt on directly onto the 99-00 Si rear disk brakes and bolt up to my 96 hatch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16 EK »</TD></TR><TR><TD CLASS="quote">i need my car fixed!!</TD></TR></TABLE>
undefinedek9
01-06-2006 06:30 PM
lowRIDAH
10-15-2004 02:26 PM
