d15b starting problems
I'm having problems with my motor. It turns over but it doesn't fire up. I got a new battery, so I don't think that is a problem. Any suggestion guys? It's a Del sol with a jdm d15b vtec w/z6 intake manifold. thanks in advance
Re: d15b starting problems (e jay one)
make sure you didn't put the dizzy on 180 degrees backwards, i known it sounds dumb but i've seen it done. Not the distributor itself but the drive comming out of it that goes into your camshaft. And of course check for spark and fuel. Good luck.
random questions:
does the starter make noise?
does the car just click and thats it?
do you have a puel pressure guage?
did it run before or did you just do the swap?
if it ran before,, what did you try and do?
random questions:
Re: d15b starting problems (slowdx9585)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdx9585 »</TD></TR><TR><TD CLASS="quote">make sure you didn't put the dizzy on 180 degrees backwards, i known it sounds dumb but i've seen it done. Not the distributor itself but the drive comming out of it that goes into your camshaft. And of course check for spark and fuel. Good luck.
random questions:
if it ran before,, what did you try and do?</TD></TR></TABLE>
Starter makes noise, when it tries to turn over.
No clicking, just trying to fire up.
no pressure gauge
just did the swap
I will try to see if there is any fuel going into the motor. (Any suggestion on how to do this?)
I will also be checking the dizzy
random questions:
no pressure gauge
just did the swap
Re: d15b starting problems (9 3 d e l s o l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9 3 d e l s o l »</TD></TR><TR><TD CLASS="quote">
no pressure gauge
just did the swap
I will also be checking the dizzy</TD></TR></TABLE>
take off the line to the fuel rail and crank the motor, just make sure you have a rag under it.
no pressure gauge
just did the swap
project civic
03-10-2005 08:35 AM
