No Check Engine Light
I've searched
I'm not a noob
I've read the rules
92 Cx
97 B18c5
When you turn the key on the ignition certain lights light up before you actually start the car, the check engine light is one of them, along with the oil.
The only lights that come one when i turn the key over is srs(which i no longer have) and battery
The car was gutted when i got it so when we starting plugging things back into there places we werent sure if there are only 3 plugs that go into the fuse box or more?
I'm not a noob
I've read the rules
92 Cx
97 B18c5
Re: No Check Engine Light (prettyQuik)
Get yourself a wiring diagram , but to my knowledge theres only three.
Check to make sure the bulbs are good, they might have pulled them because they were constantly on for some reason.
Re: No Check Engine Light (nocternaldragon)
i checked bulbs...they seem fine, its the factory civic harness so i assume everything is good. I just finished this swap and there is no way for me to tell if anythings gunna blow up if i can't check the engine...unless anyone knows another way??
Re: No Check Engine Light (byronl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by byronl »</TD></TR><TR><TD CLASS="quote">whoops </TD></TR></TABLE>
completley worthless post. if you cant contribute please dont say anything.
prettyQuik your car isnt going to blow up without an engine light, if there is a serious problem it will run in limp mode (very low rev limit, no vtec, etc) i would get your hands on a service manual and start tracing wires. its probably cut somewhere.
Re: No Check Engine Light (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">
prettyQuik your car isnt going to blow up without an engine light, if there is a serious problem it will run in limp mode (very low rev limit, no vtec, etc) i would get your hands on a service manual and start tracing wires. its probably cut somewhere. </TD></TR></TABLE>
yeah...thats the last thing i wanted to do, but it has to be done
DETROITREX
10
10-13-2002 04:02 PM
