I'm Dumb...How To Get Through Passenger Side Firewall To Wire Vtec??
yeah, i can't find any way through on the passenger side to hardwire to the ECU on my '94 hatch...i guess i can always run the wires across to the driver side and back around but that's quite a ways.
the driver side actually has a small opening around the cluster of wires going into the engine bay...but on the passenger side they're surrounded by a think *** rubber surrounding and i can't find any other way through. hepl.
Re: I'm Dumb...How To Get Through Passenger Side Firewall To Wire Vtec?? (NorcalHB94)
There should be a gromet to the right of the battery, probalby about 6" down from the base of it. It will come out behind the glove compartment, behind the vent ducting.
Re: I'm Dumb...How To Get Through Passenger Side Firewall To Wire Vtec?? (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer »</TD></TR><TR><TD CLASS="quote">There should be a gromet to the right of the battery, probalby about 6" down from the base of it. It will come out behind the glove compartment, behind the vent ducting.
Ya, it probably won't have a hole in it yet just look for a rubber "cap" I guess it could be described as. Drill through it.
Re: I'm Dumb...How To Get Through Passenger Side Firewall To Wire Vtec?? (Happyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyman »</TD></TR><TR><TD CLASS="quote">
Ya, it probably won't have a hole in it yet just look for a rubber "cap" I guess it could be described as. Drill through it.</TD></TR></TABLE>
I was actually able to just cut a slit in it with a utility knife and pull my wires through.
You can also go though where the a/c lines enter or exit the firewall on the passenger side. Use a ultility knife cut a small slit in the rubber grommet and pull the wires through (i use a bent coat hanger to pull all the wires through at once)
Re: I'm Dumb...How To Get Through Passenger Side Firewall To Wire Vtec?? (turboxsi)
ahhh, i'k i saw that little plastic plug to the bottom right of the battery facing the firewall and i didn't know if i should try to remove it or tamper with it in any way...thanks alot
you'll be fine just cut alittle slit in that grommet, and pull the wire through!
Ben Scholer
03-07-2016 05:17 PM
cornholioEK
10
12-05-2003 12:31 PM
