Installing cams...
Installing cams...
Hey guys i need to know if i will need itr camgears with the itr cams iam throwing in my car this weekend or if i can just use the stock b-16 camgears???????? Also how complicated is this process and what should the valve lash and all the other stuff be set at?
Re: (Dimi)
Honestly seeing as your a DOHC if you dont know what your doing dont do it at all, until you get a good manual from somewhere. Its real easy to mess this up.
Also if you dont have air then those cam gears are going to be fun to take off.
Re: (Luserkid)
yeah from the sounds of it, it doesnt sound like your ready to take this on yet. if your timing is off by even one tooth it could be bad news for you. but if you do decide to do this yourself i would make sure you have the helms manual, air gun shims, tourqe wrench, and make sure the motor is cold. and just to save on labor i would get the gears now so you dont have to do this all over again. but good luck!
Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Honestly seeing as your a DOHC if you dont know what your doing dont do it at all, until you get a good manual from somewhere. Its real easy to mess this up.
Also if you dont have air then those cam gears are going to be fun to take off. </TD></TR></TABLE>
Word. DO NOT DO THIS UNLESS YOU KNOW WHAT YOU ARE GETTING YOURSELF INTO. It's much easier to mess up than you think. Make sure you get the proper tools, manual, and have someone there who has done it before. Good luck.
boostedbseries2000
01-02-2005 04:21 AM
