stock exhaust with b series swap
anyone running stock exhaust system with a b series on an eg? if so, what header/cat/midpipe/axle back combination works?
ohh when i bought the car is was like this except it had a catback exhaust on. The cat that is on my car is smaller than other honda cat so it needed to be extended so thats why the cat is modded. If you dont understand me then i'll post some pics later
Re: stock exhaust with b series swap (EH-3)
here some pics of the modded cat
http://i37.photobucket.com/alb...4.jpg
http://i37.photobucket.com/alb...3.jpg
http://i37.photobucket.com/alb...2.jpg
Re: stock exhaust with b series swap (db8gsr_teg)
don't quote me on this..
I believe the stock B-Series exhaust manifold, B-Series Cat (Integ), and stock piping will work after you lengthen the stock pipe.. the cat bolts up, but is too far from the collector by about 2-3 inches.. you can't use a D-Series cat because the bolt indexing on the manifold flange is off by 90 degrees..
