Can I Remove the Door Panels with the Doors Closed?
I am a (Trial User) Army
So, for reasons unnamed, I cannot open my doors, lol. Do you guys think there's anyway I can remove my door panels with the doors closed? I haven't looked or anything yet rly.
lol, I've been getting in and out of the car dukes of hazard style for the last few days.
Re: Can I Remove the Door Panels with the Doors Closed? (mrchaos)
you should be able to at least get the back portion off and be able to get inside and open the door then remove it all together and fix the problem
Re: Can I Remove the Door Panels with the Doors Closed? (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">you should be able to at least get the back portion off and be able to get inside and open the door then remove it all together and fix the problem </TD></TR></TABLE>
And that's all I need to get. Awesome.
Suspetise...
1 Post
Re: Can I Remove the Door Panels with the Doors Closed? (litterbox)
I don't think so. There are tab thingys that have to be popped out along the sides and bottom. There may also be a screw-type thing at the place on the panel where it contacts the dash (by the mirror).
Re: Can I Remove the Door Panels with the Doors Closed? (kaiba)
i am almost positive you can get it open just enough to pull the rod to open the door...
Re: (CRR 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRR 2 »</TD></TR><TR><TD CLASS="quote">why not try and take off the plastic cover around the inside door latch and lock then see if you can reach the metal rod </TD></TR></TABLE>
Good ******* idea!
Good ******* idea!
Re: (CRR 2)
Re: (professor poon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by professor poon »</TD></TR><TR><TD CLASS="quote">it would be helpful if you would just say why you can't open your door...</TD></TR></TABLE>
Fine. I wired in deadbolts using actuators and they're hooked up to my alarm. Apparently now when I disarm the alarm the actuators do not retract for some reason. So the deadbolts stay in place and I can't open the door.
Re: (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">
Fine. I wired in deadbolts using actuators and they're hooked up to my alarm. Apparently now when I disarm the alarm the actuators do not retract for some reason. So the deadbolts stay in place and I can't open the door. </TD></TR></TABLE>
HAHAHAHAHAHAHAHAHAHAHAHAHAHA!!!!!!!! dude thats halarious. Maybe you switched a wire so when your alarm is disarmed its locked and when its armed its unlocked, did you try that?
Anyway like said above you cant really take it out without destorying it but you could pry enough back (backside of the car) to probably reach your hand in there and do what you gotta do to open it. Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrchaos »</TD></TR><TR><TD CLASS="quote">I'm sure you could remove them, but I doubt you could reuse them afterwards.</TD></TR></TABLE>
Re: Can I Remove the Door Panels with the Doors Closed? (cybergreencivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cybergreencivic »</TD></TR><TR><TD CLASS="quote">roll the windows down and dukes of hazard the bitch </TD></TR></TABLE>
is reading really that hard?
Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">HAHAHAHAHAHAHAHAHAHAHAHAHAHA!!!!!!!! dude thats halarious. Maybe you switched a wire so when your alarm is disarmed its locked and when its armed its unlocked, did you try that?
lol, it's been working for a months and now the alarm went off and it's not working right.
lol, I've been getting in and out of the car dukes of hazard style for the last few days. </TD></TR></TABLE>
Re: (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cybergreencivic »</TD></TR><TR><TD CLASS="quote">... im from Nebraska, i cant read</TD></TR></TABLE>
hey im from NE and i can read just fine
try taking off the speaker cover... put your hands down in that speaker area and pop the bottom part of the panel off, they're just tabs. work your way over as far as you can... see if you can pry it open from there. the whole bottom portion of the panels should pop off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy »</TD></TR><TR><TD CLASS="quote">There may also be a screw-type thing at the place on the panel where it contacts the dash (by the mirror).</TD></TR></TABLE>
But there is always this screw^^^^^. and you'll still need to lift it upward
kaneda3
01-15-2007 10:28 PM
shorty0o29
10-14-2003 11:39 AM
