really quick radio que. just need a answer
ok i have a 92 hatch and i want to use a 00 si radio. i have the plug beind the radio with the wires coming out of it.
how can i make this work in my hatch? do i just snip off the plug off my harness and color match it to the si radio harness? are they all color matched, will i have extra wires.
i wanna get this done right now cuz i have nothign to do and searching for this is hard
thanks
thanks
Since you have the 98+ connector w/ wiring, just match it up
http://www.installdr.com/Harnesses/HA-Wiring.pdf
...searching is easy if you try a little
Re: (pdiggitydogg)
hmm the wires were to short to splice into my harness.
what car can i cut the plugs out from and have it for a perfect match for my harness, and be able to use that link you provided. cuz looking at the old plug it didnt have the wires in the same spot in that diagram
Re: (dthug)
The wires from the Si radio plug are too short? Or your radio harness?
What I plan to do if I pick up an 02-06 CRV radio was to buy a reverse harness for the 96+ Honda radio and a harness for my 92-95 Civic. Splice them together, and plug and play.
Reverse Harness
Harness
Reverse Harness
Harness
Re: (BlueIntegraBoy)
so you think i can go to pepboys and get a reverse plug or w.e from a 98+ honda and splice it to my stock eg harness.?
btw the plugs taht were to short were the ones that came with the plug from the radio
Re: (dthug)
Yes, if you don't mind splicing into the radio harness, you can get a reverse harness and splice. The reason why I would buy the reverse harness and harness is if I wanted to switch back to my ITR radio. I wouldn't have to resplice again.
I'm not sure if Pepboys carries the reverse harness.
nbcivic
Audio / Security / Video
05-20-2010 01:36 PM
