installing 91 civic si cam into 98 DX engine
when I go an install an si cam from a 91 civic si into a 98 civic dx which cam gear am I supposed to use and how do I know where the tdc is for the cam?
My understanding is that on the 91 si engine there was a little marker on the timing belt back cover that would clearly indicate tdc of the cam. Since I'm installing my 91 si cam into my 98 dx engine do I use the cam gear that came with the si engine or do I swap it out? How do I determine the proper tdc for the newly swapped camshaft?
Is there any noticeable power gains?
thanks
thanks
Re: installing 91 civic si cam into 98 DX engine (stevescivic)
d16a6-108hp@6000 100lb/ft@5000
d16y7-106hp@6200 103lb/ft@4600
so I ask, why would you even bother?
Re: installing 91 civic si cam into 98 DX engine (Jakester9500)
that was what I wasn't so sure about....
in this case I won't bother doing it since you make a very good point.
Thanks Jakester for the headsup.
stevescivic
01-20-2007 07:32 PM
