d16z6 & d16y8
d16z6 & d16y8
ok currenly i have a 94 ex civic when i bought it, it had a g15 greddy turbo kit, but little did i know there was a boost leak. so when i fixed it .. about 100 miles later.. well it doesnt run now.. anyway i wanted to know what motor to get since the one in it is a d16z6 but i cant find a replacement anywhere i see alot of d16y8s.. i dont want to spend alot to get this fixed i may just make it stock and take the turbo off of it..
Thanks for your time
Shaun
Also.. i did do some searchin on this but turned up with the d16y8
Shaun
Re: d16z6 & d16y8 (dr92cx)
yes if i can get away with just getting a d16z6 i will but if i can get the y8 i will too.. i need the cheapest way out
Re: d16z6 & d16y8 (commotion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by commotion »</TD></TR><TR><TD CLASS="quote">yes if i can get away with just getting a d16z6 i will but if i can get the y8 i will too.. i need the cheapest way out</TD></TR></TABLE>
From the sticky at the top of the forum...
https://honda-tech.com/zerothread?id=694733
5th Generation (1992-1995)
EG1 D15B JDM All 3-door/4-door/CR-X
EG1 D15B8 USDM 1993-1995 del Sol (8-valve)
EG1 D15B7 USDM 1993-1995 del Sol S (SOHC)
EG1 D15Z1 USDM 1993-1995 del Sol VTEC-E (SOHC)
EG2 B16A JDM All 3-door/4-door/CR-X
EG2 B16A3 USDM 1994-1995 del Sol VTEC (DOHC)
EG3 D13B JDM All 3-door/4-door
EG4 D15B JDM All 3-door/4-door/CR-X
EG5 n/a JDM All ? (ZC DOHC)
EG6 B16A JDM All 3-door/4-door/CR-X
EG7 D13B JDM All 3-door/4-door
EG8 D15B JDM All 3-door/4-door/CR-X
EG8 D15B7 USDM All 4-door DX/LX
EG9 B16A JDM All 3-door/4-door/del Sol CR-X
EH1 n/a JDM All 4-door/4WD (ZC DOHC)
EH2 1.5L USDM All 3-door CX/VX/DX
EH3 D16Z6 USDM 1993-1995 3-door Si
EH6 D16Z6 USDM 1993-1995 del Sol Si (SOHC)
EH9 D16Z6 USDM All 4-door EX
EJ1 D16Z6 USDM All 2-door EX
EJ2 1.5L USDM All 2-door DX
So, looks like your car originally came with a z6. So you should be fine.
EDIT: And as long as you use the whole engine (not swapping heads or whatever), swapping the y8 is easy and will work too. You have to mess with the OBDII to OBDI though.
Modified by dr92cx at 12:29 PM 2/1/2007
Re: d16z6 & d16y8 (Jakester9500)
has a knock i havent taken the head off yet but i think it is a knock
also york. pa is like 35 mins from meh lol
both blocks would work fine. if i were you i would take the engine apart see what damage there is if the block is ok i would buy new rods and pistons and put the turbo on that.
Re: d16z6 & d16y8 (uo959)
Dude, if you really need a y8 block I have one I will sell for $150. I visit Springfield, MO. all the time if you would want to driver there to pick it up. Let me know.
