Water in driver's side footwell
Yea so my driver's side carpet in getting wet but it hasnt even rained recently and I know it was not wet yesterday so what could it be? Where could it be leaking from? Its a 97 hatch if that makes a difference. Help me out guys! thanks
hah i have a gutted interior and i have noticed this as well.... its right by the ECU too! ahhhhhhhhhhhhhhhh
maybe tommorow i will inspect the area and see where its getting in from.
Re: (allricedout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">hah i have a gutted interior and i have noticed this as well.... its right by the ECU too! ahhhhhhhhhhhhhhhh
Maybe tomorrow i will inspect the area and see where its getting in from.</TD></TR></TABLE>
Ok the side were your ecu is there should be a hole on that side of the car were the ecu attaches look for it, it is there then all you have to do is plug that hole and that will take care of your water problems i used a plug from Honda and took care of this problem
Off topic:-
I also have full gutted interior have you weighed your car yet? and if so how much did it come in at?
Off topic:-
Re: Water in driver's side footwell (bart2546)
u 100% sure its water??? is it a manual tranny??? if so, your clutch master cylinder is probably leaking. check your clutch fluid resivoir. my 92 accord's clutch master cylinder was leaking and u can see drips running down by the clutch pedal.
Re: (richard7968)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richard7968 »</TD></TR><TR><TD CLASS="quote">Ok the side were your ecu is there should be a hole on that side of the car were the ecu attaches look for it, it is there then all you have to do is plug that hole and that will take care of your water problems i used a plug from Honda and took care of this problem
Off topic:-
I also have full gutted interior have you weighed your car yet? and if so how much did it come in at?</TD></TR></TABLE>
thanks yeah ill try that asap..... i havent weighed my car yet but i plan on doing it at a scrap metal yard or something.
Off topic:-
Re: (allricedout)
thanks yeah ill try that asap..... i havent weighed my car yet but i plan on doing it at a scrap metal yard or something.</TD></TR></TABLE>
did mine come in at 1980lbs
SoullessJapaneseMachine
12-07-2007 11:31 AM
