FUEL INJECTORS..? QUESTION
i have a 95 LS motor and i am using my stock single cam fuel injectors, would this set up make my car not to give enough gas, or are all fuel injectors the same.. When i mean the same, Are all OBD1 fuel injectors the same or you have to use the same fuel injectors as your motor..?
Re: (blackhatchsd)
u need b series fuel injectors d series wont give u enuff fuel will lean out at higher rpm dosnt matter what b series gsr u will run rich b20 would work fine if u cant find ls
