Just did a compression test today? What you guys think
Hey H-T members,
I just finish my compression test today. What you guys think? I was looking for the psi range on the manual but I couldn't find it. This was perform on a 2000 Honda Civic SI B16A2. with roughly 83,000 miles. Cold temp, WOT, 5 crank, anti-sieze the tread, analog compression test meter.
Cyl#1 Cyl#2 Cyl#3 Cyl#4
195 197 197 195
Thanks
195 197 197 195
Thanks
Re: Just did a compression test today? What you guys think (. a d a m)
Next time make sure the motor is up to operating temp before you perform the test.
You should be right around 200 and you are so the motor is strong
Re: Just did a compression test today? What you guys think (Ep_Kevin)
My SI is at about 76k and I had around the same numbers as you the last time I did a compression check.
Re: Just did a compression test today? What you guys think (yan_david)
do you guys think that I would have bent valves? there ticking but I already had a valve adjustment done. I heard that it could be injectors. is there a way to check? thanks
hybrid1990crx
09-13-2005 05:36 PM
