Coilover O-Rings (tried searching)
Ok.. I have no idea where these go..
Ring "C" is metal.
I'm fairly sure rings "B" go inside part "1". Right?
Ok.. I'm lost..
please help me real quick!
Ring "C" is metal.
Ok.. I'm lost..
Re: Coilover O-Rings (blackrag)
Ok the o-rings go over the shock absorber body, then you slide the threaded collar(#1) over them, next you sit the springs on the perch and last you put the top hat on(#3).
Good luck!
Good luck!
Re: Coilover O-Rings (JavierP.R.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JavierP.R. »</TD></TR><TR><TD CLASS="quote">Ok the o-rings go over the shock absorber body, then you slide the threaded collar(#1) over them, next you sit the springs on the perch and last you put the top hat on(#3).
Good luck!</TD></TR></TABLE>
thanks for the quick responce! all the o-rings go on the shock?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackrag »</TD></TR><TR><TD CLASS="quote">
thanks for the quick responce! all the o-rings go on the shock? </TD></TR></TABLE>
Not all the o-rings. You need two for each shock, one towards the top, one towards the bottom. You have different sizes there. Obviously, you want to use the biggest ones you can and still be able to fit the threaded collar over the shock body.
Re: Coilover O-Rings (sniggler316)
thanks for the help. i just played it by ear.. (ya know what i mean) and it worked out fine.
now work.. then the other three.. blah...
Larkin W.
03-20-2007 02:13 PM
