power window help
power window help
well my passenger side window roll down but not up. I checked the motor and it working fine . It roll down perfectly but it won't roll back up. Seem like there is no power when going up.. Does anyone know what could be wrong. Btw its for 95 coupe.
Re: power window help (ug1yu)
i had a 96 coupe and i had to replace both the passenger and drivers side motor and the track that the window slides on. you window may have jus slipped off the track and it would be an easy fix. when your window went down did it go down slowly or sound like it was struggling to get down? if it did then you would probably have to replace the track or find some way to straighten it out or clean it off.
it went down just fine. not sluggish. Well both switch is clean. Btw both switch doesnt work for the passenger but the driver side is ok. As for the track i will check right now . thx for the response
Just checked track every seem to be intact. Rubber is still good. The problem is there seem to be no power when pushing the switch to roll up. but down is ok.
Modified by ug1yu at 5:44 PM 6/15/2007
