question about twm 50mm itb's
Can they work with a mugen p28 chip, apexi and 440cc injectors?
specs:
b18a1 block sleeved and bored to 84mm
b18a1 stock crank
b16 head ported & polished
probe I beam rods
13.2:1 wiseco pistons
jun3 cams
ferrea outer springs & stock inner springs
ferrea retainers
rev flat stainless steel valves
stock b16 flywheel
4 puc clutchnet disc
act pressure plate
walbro 255 fuel pump
venom cam gears
unortodox crank pulley
balanced
etc.
with a skunk2 im, holley 68mm tb, 345cc injectors and custom 3" cai, made 226.9whp & 150.4wtq and 12.3@ 106.8mph
specs:
b18a1 stock crank
probe I beam rods
jun3 cams
ferrea retainers
stock b16 flywheel
act pressure plate
venom cam gears
balanced
etc.
been there done that
Re: (b18master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18master »</TD></TR><TR><TD CLASS="quote">It works really nice I just use 3 gal. of 93 octane fuel for each gal. of vp c-12 to stop knocking at low rpms.</TD></TR></TABLE>
or you could use an actual tuning program and be perfectly fine with regular 93. hell you might even be able to squeeze out a few more hp by tuning the fuel and ignition maps seperately.
I already sold the complete intake system, and finished port matching the new itb's.
I will install them tomorrow and will try to tune them a little bit so I can get to the dyno on monday. I have a friend that knows how to work with crome, hope he could go with me...
