Question about an O2 sensor on a 97 civic ex
Re: Question about an O2 sensor on a 97 civic ex (kaluwa3)
If you buy an oem sensor than it will plug right up...if not you will have to splice the wires from the harnes to the sensor together...its just 2 wires
Re: Question about an O2 sensor on a 97 civic ex (cimo463)
So any honda o2 sensor will work? Or does it have to be made for a 96-00 civic, or be OBD2???
it needs to be the sensor that goes in the header...not the sensor after the cat...but any obd2 honda sensor will plug right up
Did you try heating up around the sensor with a torch and then removing it? Sometimes that will break um loose. Or spray it down with penetrating oil? Kroil can work wonders.
Re: (Tzer)
Yeah we tried everthing.. the sensor is stuck, and it's not coming out, at least in one piece.
So he just has to get any OBD2 "Front" o2 sensor? Is the header sensor considered the "front" sensor, or is there a dif name for it?
Also whats a good price for one new? would anyone reccomend buying a used one?
