jdm sirII guage cluster had burnt out bulbs, send it back?
* B A N N E D *
i bought one from HMO and plugged everything in right and only about half the lights come on.... im kinda pissed because i paid over $170 for the cluster....
what should i do?... btw can i even get replacement bulbs locally?
Re: jdm sirII guage cluster had burnt out bulbs, send it back? (LudeSH)
That's real, save the time and energy. Switching out all the bulbs when you go JDM cluster is similar to changing the clutch when you get a swap; you just do it while it's out. Happened the same with me.
Re: jdm sirII guage cluster had burnt out bulbs, send it back? (akunamatta)
I've noticed most of the EG6 clusters I have received, some bulbs were burnt out. The solution is to swap over bulbs from your USDM cluster, but remove the blue condom first. Or buy replacement bulbs from your local automotive store.
H-T White Ops
You don't need the part number.
And chaning JDM bulbs is just the same as changing USDM bulbs or bulbs form any other country.
It's pretty easy. Twist and they pop out.
Re: (NOFX)
Yeah, don't even bother taking them out of the socket, just exchange them with the corresponding bulb and socket from your USDM cluster (sans the condom), and you should be fine.
* B A N N E D *
okay so the usdm bulbs are the same just without the amber condum? okay, where can i order them?... also if someone has a link on how to do it id appreciate it.
Re: (akunamatta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akunamatta »</TD></TR><TR><TD CLASS="quote">okay so the usdm bulbs are the same just without the amber condum? okay, where can i order them?... also if someone has a link on how to do it id appreciate it.</TD></TR></TABLE>
Just take the bulbs/sockets from your old USDM cluster, remove the blue condom, and stick them into the JDM cluster. There are no amber condoms.
* B A N N E D *
Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Go to any automotive store and pick up...
5 - #24 bulbs
1 - #74 bulbs</TD></TR></TABLE>
thanks man!!!!!!!!!!!!!!!!!!!!!!!
5 - #24 bulbs
HT White Ops
Re: (akunamatta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akunamatta »</TD></TR><TR><TD CLASS="quote">sorry for bumping this but i was wondering if someone has a "how to" on replacing these..... i am going to try and do it today.</TD></TR></TABLE>
The bulb sockets twist out, and then the bulb pulls out of the socket. Are you simple? You have the know-how to install a cluster, but you can't figure out how to change a light bulb?
* B A N N E D *
HT White Ops
Re: (akunamatta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akunamatta »</TD></TR><TR><TD CLASS="quote">wow dude stfu..... i found a link that should help https://honda-tech.com/zerothread?id=661308</TD></TR></TABLE>
Wow dude, stfu. Just because you're a simpleton. I'm glad you got up off your *** and searched for something a two-year-old could figure out.
yea man... changing a bulb is pretty simple. Use the how to on swapping out the cluster, then before you install it, twist oout the little lights and replace them.
I got a joke for everyone!!
"how many akunamatta's does it take to change a light bulb?"
* B A N N E D *
Re: (erixxxhouse)
ok, i have a serious question..... i have two plugs that are white and yellow can i plug them into my jdm cluster or not?
see how his are green and yellow?.... i cant see a spot on where to plug mine in at
HT White Ops
White/Blue are main cluster plugs. Green is cruise control, yellow is SRS, and orange is ABS. Plug in what you've got. If it's not plugged in, it won't light up, so it really doesn't matter.
* B A N N E D *
i have a yellow and white behind my dash.... and i cant find a spot anywhere on my cluster to plug them in at.... wtf! im starting to get pissed
HT White Ops
Re: (akunamatta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akunamatta »</TD></TR><TR><TD CLASS="quote">i have a yellow and white behind my dash.... and i cant find a spot anywhere on my cluster to plug them in at.... wtf! im starting to get pissed</TD></TR></TABLE>
Ok, maybe I gave you too much credit.
Re: (akunamatta)
dude eran answered your question already. if you don't have any place to plug the other plugs into the cluster, then your done.
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">White/Blue are main cluster plugs. Green is cruise control, yellow is SRS, and orange is ABS. Plug in what you've got. If it's not plugged in, it won't light up, so it really doesn't matter.</TD></TR></TABLE>
For the 92-95 Civics, the main cluster plugs are grey, not blue like the 96-00 Civics. The white and yellow plugs are for shift light and SRS plugs respectively.
You don't need to plug them in. Your cluster will work just fine.
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">The white and yellow plugs are for shift light</TD></TR></TABLE>
I forgot about the "econo-light" .... it's been a long time since I've driven a 5th gen. My stupid truck had that thing.
