Joined EG hatch crew today...advice on fixing front end damage please
Hello, happy to say i joined civic crew. The local scrap yard has a clip, so they're gonna cut wherever, and i'll cut/weld the new section. This'll be my dd project for a while so i want to do things right, basically not sure where to make the cuts and where to weld so everything fits. thanks for your advice. Also I'm wondering about fiberglass fenders and hood to save weight. Heres pics for reference.
Re: Joined EG hatch crew today...advice on fixing front end damage please (drift2004)
i bought your for $649...i kinda didn't want to spend that much but there was other interest, so i figured minus well. I'm gonna fix the front end, and dd it till i can afford a b series and suspension
Re: Joined EG hatch crew today...advice on fixing front end damage please (onehalfasia)
you need a rad suport, bumper reinforcement and left apron.....Just drill out the spot welds that hold those parts in place.....No cutting.
Re: Joined EG hatch crew today...advice on fixing front end damage please (E.Honda)
sweet thank you, dont have a welder either, is there a certain type i should use?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onehalfasia »</TD></TR><TR><TD CLASS="quote">sweet thank you, dont have a welder either, is there a certain type i should use?</TD></TR></TABLE>
Mig welder...you can rent one.
that doesnt look that bad. just make sure after you get the radiator support you TEST FIT EVERYTHING before you even think of welding it down. i mean hood, fenders, bumper, headlights EVERYTHING. you dont want that think all cockeyed and fitting like **** now do you? didnt think so. trust me, test fitting everythign can save you so much time money and its less of a hassell in the long run.
Re: Joined EG hatch crew today...advice on fixing front end damage please (he_who_corrupts)
good idea, so basically tack the parts and once everything visually fits properly, weld everything into place.
thatts not a bad idea, but just just dont put so many tacks on it that in the event its off you still save it and not have to sit there and grind off 50 tacks. start from the hood, because its a one fit deal there is not much room to move the hood around, then line up the radiator support and fenders then the bumper. if worst comes to worst, rout out the fender holes and push in/pull out the fender whichever way it needs to come to line up good with a good gap from the hood
Mikey361
06-16-2006 07:11 AM
