Zex Kit
Old 06-15-2007, 11:36 PM
1BADEGDC2's Avatar
Default Zex Kit
So my friend happens to have a dry zex kit with a 55 shot. I plan to go to the tracks this wednesday, and wanted to know if anyone has installed it before? How hard is it? It will be going in a 92hatch with gsr swap. I got the insturction off zex but they are kinda confusing. If anyone could help i would really appriciate it. Thanks for everything.
Old 06-22-2007, 01:35 AM
1BADEGDC2's Avatar
Anyone???
Old 06-22-2007, 12:13 PM
EJ2*Whitey's Avatar
Default Re: (1BADEGDC2)
If you can't hook up a nitrous kit, then you shouldn't own one.
Old 06-22-2007, 12:48 PM
Malakai's Avatar
all dry kits are pretty much the same regardless of the brand. just search on google and im sure u can find some instructions.
Old 06-22-2007, 01:36 PM
runawayboy's Avatar
Check out the Zex website. I know you have to hook up the box to the tps sensor, and you have to drill a hole in your air intake. The instructions are fairly easy, which part is confusing you?
Old 06-26-2007, 09:44 AM
1BADEGDC2's Avatar
Wanted to know how hard it was gonna be? If anyone had some tips they could give me
Old 06-26-2007, 10:14 AM
2wheelhunter's Avatar
installation is rather simple... risk is too big unless you have the fuel system to support it i think. try searching honda-tech i found a few reallllly good write ups on dry kits
Old 06-26-2007, 10:59 AM
forcefedferio's Avatar
Default Re: (2wheelhunter)
Zex's website has a complete guide printable on Adobe Acrobat or whatever you are using, i think it's something like 25 pages long and includes everything from step by step installation, programming, and tips.
here's the site actually for 4 & 6 cyl dry kits
http://www.zex.com/Base/Instructions/ZEX109.pdf
i would also recommend getting some spark plugs with a heat range of 8, NGK's work perfectly and are available at any local auto parts store
Old 06-26-2007, 11:03 AM
Default Re: (forcefedferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1BADEGDC2 &raquo;</TD></TR><TR><TD CLASS="quote"> I got the insturction off zex but they are kinda confusing. If anyone could help i would really appriciate it. Thanks for everything.</TD></TR></TABLE>
whoops didnt see this part you already had the instructions....well it's just kinda straight forward with the zex kit, hook up the main nitrous line to the box, the nitrous line to the intake, wire it up, tee in your vacuum line hook up the arming switch and program the box specified in zex's instructions.
Old 06-27-2007, 02:54 AM
1BADEGDC2's Avatar
Thanks for the help guys!
lude98SH
05-27-2007 05:11 PM
MajinB
03-20-2006 05:02 PM
AL ASPIRATED
05-06-2004 04:47 AM
KoRE
03-22-2003 10:06 AM
EGkTiOn_CiViC
05-31-2002 10:26 AM
Quick Reply: Zex Kit
