Motor throwing out oil....????
1 Post
I noticed A LONG *** time ago that my motor burned oil.... LSvtec. Whatever its inevidable.... But I also have a bit of a leak. Changed the camseals as i thought it was coming from them. Didnt seem to solve the problem, and seems to actually be worse now..
The oil keeps dripping from the corner of the oil pan off of my traction bar to the floor.... It actually shoots up the entire front of the block when I drive on the freeway too so its starting to **** me off. I have a hunch it may be coming from behind the crank pulley...
This is why i started the thread.... Is this even possible???? I felt along the back of the pulley and its pretty bad. After looking at www.acuraautomotiveparts.com I couldnt find a seal for the crank pulley??? I really dont know whether or not its truly coming from there or not anymore.. Thoughts????
1 Post
I spoke with a friend/shop owner. He said he wants to pull off the crank pulley and plastic housing and see if it may be the front main seal...If so Im gonna have to swap out the timing belt earlier than expected but at least I will be fixing the problem though... I should have some news by then.
