JDM OBD1 B16A Vtec Solenoid Gaskets Part Numbers
once upon a time ago back when this forum didn't suck i had it saved some where on my recently viewed forums...
i may be remembering incorrectly but the vtec solenoid gaskets are the ones off of a NSX
the distributor/alt would be off a 90-93 teg
and the rest of the parts are off any b16 motor...
that is for the OBD-0 version of the b16a... i could be wrong but i remember asking in the EF forum because i have the same type of motor and i was getting pissed trying to find parts and make sure that they were right before i got home.
Im not positive but i think the nsx gasket is only good for the OBD0 B16 motor. Im not sure if you can use a nsx gasket on a OBD1 B16 motor.
Another question also, the gaskert or o-ring thats used to seal the part where the dizzy goes into the motor. I also need that part number.
Former Moderator
I order them for a 1994 Del Sol VTEC - #12 and #14 seen here:
Majestic doesn't list the part #s but just ask your local dealership for 1994 Del Sol VTEC (make sure they know it's the B16A3 one, not the D16Z6 one) VTEC solenoid gaskets - hell print this picture up and take it to them.
BTW you can also get #25 and replace it by removing the VTPS off the solenoid since you're already going to be in that area.
Former Moderator
Yeah #25 goes around the VTEC oil pressure switch.
Distributor o-ring is also ordered for 1994 Del Sol VTEC. I say 1994, but other years work too, but we'll just keep it at 1994 for simplicity's sake.
Yobee
12-09-2012 08:16 AM
speedfreak44
07-04-2010 07:20 PM
93delslow315
02-08-2010 04:55 PM
