need help adjusting coilovers please!!!!!
i have tokico coilovers on my eg hatch and i need help raising the rear suspension. ive never adjusted a coilover and i was told u need a special wrench but i never got any tools with the car. can anyone fill me in on what i need, how i do it and how long it would take to adjust the back to shock towers.
Re: need help adjusting coilovers please!!!!!
Jack up the car, loosen the bit nuts on the coilovers and spin them up/down to move the ride height down/up. IDK about the tools, maybe just knock them loose/tighten with a wood hammer handle?
its called a spanner wrench.
Call tokico to see if they sell replacement spanner wrench for your coil overs.
till then you can use a flat head screw driver and a hammer.
stick the flat head into the notch of the nut, then tap it loose and spin it by hand.
good luck
good luck
hey, guys! i have a 2000 honda civic si and i wanna the do the suspension on it but i wanna do it really good but with spending around $2000... so far i picked out these parts and im thinking i made pretty good choices but i wanna know what the rest of you guys think??? i need as much info as i can get before i order all these parts so give me as many helpful hints as you can please!!! thank you!
ASR Rear Subframe Brace
Skunk2 Pro-S Full Coilover Kit
ASR Spherical Rear Sway Bar End Links
Skunk2 Rear Lower Control Arms
Skunk2 Rear Tower Bar
Skunk2 Front Tower Bar
ASR 24mm Swaybar & Bushing Kit
Skunk2 Pro Series Plus Front Camber Kit
Skunk2 Pro Series Rear Camber Kit
I also use Tokico, with Coil-overs, and I will tell you from Experience,
USE SPANNER WRENCHES..
It can cost about 10-20 bucks and worth it..
You need to torque the two collars against each other, so they do not vibrate loose..
If someone else had "good luck" with it, good, but, I would recommend that if you can get some spanners, use them..
I also like to tap the bottom collar to make sure its tight against the top collar..
Good luck.
Good luck.
users
08-07-2005 12:29 AM
sharkey65a
03-01-2003 09:59 AM
