installed a new cluster..now nothing works
i have an si, it had a cx cluster, put in an ex cluster...nothing works. temp, fuel, tach, speedo, lights. when i turn the key on, engine off, the only light that lights up is the battery light. no srs, ses, or anything like they should when you do that. when i turn on the right blinker, it lights up on the dash, left turn does not light up. i checked every fuse known to man and nothing is popped. i tried putting the cx cluster back in, and it is doing the same thing. wtf
Re: installed a new cluster..now nothing works
I sucessfully replaced a stock DX cluster with an Si cluster. The DX did not have a tach, but the Si cluster did. I just plugged in 3 of the 4 connectors, and EVERYTHING works perfectly. However, if you have 4 connectors, maybe you need a 4 connector cluster.
Try checking all of your plugs. Make sure they are in tight. Shouldnt be the new cluster if its doing that to your old cluster.
akaEsCo01
08-25-2003 10:46 PM
