DIY Combination Switch Fix (Headlight Switch) AND Wiper Combo Switch - Honda-Tech - Honda Forum Discussion
Old 03-22-2009, 03:40 PM   #1
danomatic93's Avatar
Default DIY Combination Switch Fix (Headlight Switch) AND Wiper Combo Switch
With age and use the Combination Switch (Headlight switch) will fail to turn on the headlights, sometimes intermittently. Itís annoying and there is a way to fix it.
VIDEO 1
Quick video:
1. To start, remove the steering columnís three screws and remove the column. (step 2 in manual image)
2. Turn the steering wheel so that you can remove the two screws holding the Combination switch in. Then unplug the two plugs to remove the switch. (step 3 in manual image)
3. Remove the two screws on the back of the switch.
4. Notice that the pin shield is a separate piece from the pin piece underneath. If you hold the pin piece underneath down, you can pull the top shield piece off. Pull from the side with the two screw holes.
5. Notice the two little white tabs below the pins (seen in image above). They are part of yet another separate white piece. Also, notice that just like the previous step, you can hold down on this new white underneath piece. So, press in these two white tabs while holding the white piece down and pull up on the top pin piece.
Once that top pin part is off, hereís what youíll see:
Make sure the contact piece on the left stays in the middle otherwise youíll lose you blinkers.
Everything is now apart:
6. Clean the contacts on the underside of the piece with the pins. My tool of choice is a Q-tip and rubbing alcohol. It should look like this after being cleaned:
7. Lubricate the contacts. Add some dielectric grease to the contacts. You can use some of the grease thatís in the switch or grab a $1 pack of dielectric grease next time youíre at a parts store.
8. Reassemble
VIDEO 2
Quick video of checking operation of the other side of the Combo Switch. Basically just an inspection and finding the springs, to replace any broken ones, would be quite difficult to find:
VIDEO 3
Wiper Combo Switch, procedure similar to Headlight Switch, so if you need check out this video for a quick walkthrough:
Dirty
Clean
danomatic93 is offline   Reply With Quote
Old 03-22-2009, 04:12 PM   #2
Oh look, I can change this
deschlong's Avatar
Default Re: DIY Combination Switch Fix (Headlight Switch)
Hey - wow. This is great. I'm having a similar problem, but with my wiper switch, not the combination light switch. I would imagine that the procedure is much the same, and this DIY gives me hope that I can fix that problem myself, too.
Great work. Cheers.
deschlong is offline   Reply With Quote
Old 03-23-2009, 01:39 PM   #3
New User
OMeO's Avatar
Quote:
Great work. Cheers.
98 civic ex windshield wipers won't stop!!! What can i do to fix this?
OMeO is offline   Reply With Quote
Old 03-24-2009, 09:50 PM   #4
Default Re: DIY Combination Switch Fix (Headlight Switch) AND Wiper Combo Switch
Updated to include the opposite side of the Combo Switch and the Wiper Combo Switch.
Old 03-24-2009, 10:35 PM   #5
big_boosted_teg's Avatar
nice
big_boosted_teg is offline   Reply With Quote
Old 01-30-2010, 08:37 AM   #6
tslats's Avatar
thanks for the write up. This fixed my no dash light no tail light issue. Thanks again.
tslats is offline   Reply With Quote
Old 05-17-2010, 09:10 PM   #7
SHG_Claudio's Avatar
Ill subscribe to this. My headlight combo switch started making a burnt smell and then my headlight kept going on/off and now it just stays on. Ill have to find another one in the morning.
SHG_Claudio is offline   Reply With Quote
Old 12-04-2010, 05:47 PM   #8
willymccoy's Avatar
Hey, thanks for posting this up!! Both my headlight and wipers are acting up. I'll pull both switches out tomorrow and clean the hell out of them. My wipers came on automatically after I started up the motor and would not shut off. I stopped the motor at a red light and they went back to normal again. With my headlights it all depends on how cold it is outside - the colder it is the longer it takes the headlights to go on. Must be dust and Jack Russell hair.
willymccoy is offline   Reply With Quote
Old 12-04-2010, 06:53 PM   #9
You could try this but I just got another used one and it works fine.
Old 12-04-2010, 07:38 PM   #10
H-T White Ops
NOFX's Avatar
Wish I'd known this yesterday when a lady with a '99 CR-V was having this very same problem.
She wasn't very mechanically inclined and didn't mention that she had anyone who could help, so perhaps it's for the best.
I'll remember this for some of my "broken" switches though.
NOFX is offline   Reply With Quote
Old 12-04-2010, 07:42 PM   #11
Seagull Management
94EG8's Avatar
Good writeup This reminds me that I have to see why my turn signals only cancel when making right turns.
94EG8 is offline   Reply With Quote
Old 12-05-2010, 03:13 PM   #12
deschlong's Avatar
Quote:
Yeah, but isn't that because yours nearly caught fire and melted?
Quote:
That is definitely one of my pet peeve problems that would drive me nuts. Might not be the switch in your case - could be the turn canceler.... uh, which is attached to the switch ... ok nvm.
Old 12-05-2010, 03:15 PM   #13
That is true! Looks like a lot less hassle to just get another one.
Old 12-08-2010, 11:18 PM   #14
willymccoy's Avatar
You have to be careful when you snap all the sub assemblies apart. There is that see-saw on the circuit board above the white piece that is only notched in and held in place by gravity. Mine dropped down further into the switch and hung up the indexing for the turn signal switch. I had to take the other cover off which is another story in itself. It took a little bit of figuring on how to get the spring and other works back together. By the time I got it all together I ran out of daylight. I will install it tomorrow.
The whole reason I took it apart and cleaned it was because the colder the weather the longer it takes the head lights to come on. I think the problem is in the headlight socket(s) or the headlight harness. Great write up all the same.
Old 12-12-2010, 06:35 PM   #15
That's certainly your prerogative. I made the write up so that you could make the decision whether or not it's worth your time. I figure if it's salvageable why toss it, just fix it.
Old 12-28-2010, 10:55 AM   #16
Dumped DB2's Avatar
after doing step 3, i noticed on mine that around one of the small white tabs, it looks like its melted and I cant complete this step...i know i have to replace this now but why is it melted? is this common? mine is a 99 civic ex
Dumped DB2 is offline   Reply With Quote
Old 12-28-2010, 05:22 PM   #17
If it's already melted you're not likely going to be able to fix it easily without a donor assembly. When the points of electrical contact get dirty, the flow of current becomes more and more restricted. This produces heat which can be hot enough to melt the surrounding plastic parts.
Old 03-04-2011, 01:17 PM   #18
great write up. also having similar issues with headlight switch. lights come on, but not interiors, clock, or tail lights. i was also getting a burning smell from the switch. i was thinking it was a fuse box issue, but after reading the write up and reviews i'm almost certain this will fix it. i think i'll give it a try tonight.
thanks for the great write up!
jack4TT4CK is offline   Reply With Quote
Old 03-09-2011, 03:00 PM   #19
awsome write-up...did this yesterday....what do you know, my dim lights work!
hoytheld is offline   Reply With Quote
Old 03-09-2011, 09:19 PM   #20
Cap'N Chronic's Avatar
Wow. I would come across this thread the day after I order a new combination switch. Fml. Lol oh well, only 30 bucks.
Cap'N Chronic is offline   Reply With Quote
Old 04-02-2011, 08:24 PM   #21
My switch wasn't working so i took out the motor. it was fine. but when putting it back the joints that spin now keep slipping. so i got no wipers until i replace that. As far as the switch goes. i would test each contact point they all seem to work. when i opened up the wiper switch. the white part on the inside was missing? So when you turn it for the wipers the little *** wouldn't be pushing on anything. messed up huh...Someone took it out
FTVZimmy is offline   Reply With Quote
Old 06-02-2011, 05:28 AM   #22
egerdahl's Avatar
Very good job on the write up. Its not fun when your low beams just shut off going 70 MPH. SURPRISE!! I think it freaks other drivers out too ha. I'm going to clean the switch up tonight after work. I never knew it was such an easy job. Thanks for the great info.
egerdahl is offline   Reply With Quote
Old 06-02-2011, 10:17 AM   #23
Quote:
^^That's exactly what motivated me to open one of these up for the first time! I had to drive 1.5 hours on the highway in the dark with only my parking lights on. Not fun at all.
Old 06-03-2011, 12:58 PM   #24
egerdahl's Avatar
Quote:
Well I took it apart today and it was really nasty in there. I could see where some of the plastic was starting to melt so it was a little difficult to get it apart. Cleaned it all up and put some fresh dielectric grease in there. While I had the column apart I cleaned the wiper switch up because the low setting almost never worked. So far all is working well and if down the road they act up again, I'm not out any money. Thanks again for the info.
Old 06-12-2011, 01:23 PM   #25
Worked great thanks for this great tip.
aaron_drifter is offline   Reply With Quote
DIY: EG Cluster and Dash Lighting Modifications danomatic93 Honda Civic / Del Sol (1992 - 2000) 55 02-06-2018 09:35 AM
NY 1985 Bmw 325 Restored Euro/Hartge/Recaro/Houndstooth/Rust Free E30 PR3LUDE Vehicles for sale 2 11-22-2016 04:07 PM
NY 2006 Bmw 330i Black 6MT, Sport Package, Bbs Lm's, Bc Coilovers, Dukes Dynamics PR3LUDE Vehicles for sale 7 08-22-2016 08:25 AM
DIY Parking Pole on LHD Civic danomatic93 Honda Civic / Del Sol (1992 - 2000) 48 08-15-2016 11:50 AM
Tags
90, 98, accord, broken, civic, combination, fit, fix, head, headlight, honda, hondatech, light, screw, switch, two, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
