factory keyless entry
i have a 2000 civic lx. is there a way i can find out if it came with keyless entry, or if i can get a factory remote and get it to work?
thanks
thanks
Re: factory keyless entry
i know that i have a 99 civic 4 door with the value package (basically an lx with a few added features) and mine came with the remote so its definately possible to buy it. In the process of buying an 00 si, i talked to the guy and he said that they have black boxes that you can buy that the remote works through (whether or not this is true idk). all i do know is that i also have a 96 civic ex that i had to splice the old radio back into the car with the new head unit becase thats how the 96-98's are... the 00's im not sure about... sorry i said all this and it didnt help....
well if it didnt come with the car then its not gonna have anything that you can just program. i would assume that its a matter of installing something (black box) in order to get the keyless entry. Or, if you want, because i know that mine is only remote entry and no alarm, u could get an aftermarket alarm which will allow you to have an alarm and the keyless entry...
when i got my motor it had an aftermarket alarm installed with remote locking it was a meta alarm system. but at the time both key barrels where busted in so i got some body filler and filled the holes, sanded down and repainted them. keyless entry BUT!! YOUR F##KED IF YOUR BATTERY DIES AND CAR IS LOCKED! i had too crawl through the boot into the car! lol
i found a white box part #38380-s04-a020 behind the drivers kick panel. is that for keyless?if so i should be able to get a remote and program it right? also i dont have a stock radio, do i need it?
Does the box look like the one in the diagram? Is it attached to an 18P connector? If so, buy a remote and you should be good to go. The stock radio is not necessary for 99-00 Civics.
ej8ster96
05-09-2012 07:13 AM
supadupamikey
07-08-2007 11:09 AM
VR6 driver
05-31-2005 03:44 PM
