Question on Bolts
Question on Bolts
Well i was wondering if anyone had a link to either a site or a pdf that can tell me what bolts i need for my engine mounts and trans bolts for my b series swap.
Re: Question on Bolts
are you looking to buy them if so i got 2 buckets full of honda bolts will sell cheap give me a call 860-883-9374 or email me at hybridmath@aol.com
Well i don't know what car you have, so i assumed it was a 92-95 civic, in that case, the engine motor mount bolt is 90182-SR3-000 and the transmission mount bolt is 90183-SR3-000. Also if you are looking for the rear torque mount bolt, it is 90165-SM4-020. An the left and right torque mounts use studs, so i assume you don't need those.
Try not to jack peoples thread, but if you want to know, you need to give what car/engine, and more specifically what bolts u want. do u want the tranny to engine bolts, the flywheel to engine bolts or the clutch to flywheel bolts?
thats the thing, his question on motor mount bolts hasnt been compleley answered. i would be happy to tell you what part numbers you need if you would provide me with the information required above. Ill even answer it in this thread because i dont think it will deviate too much from the topic. but next time it would be just as easy to start your own topic.
the Op's car or roll dogs? here are all the answers lol:
Trans mount: 90183-SR3-000
Rear Tq mount: 90165-SM4-020
the motor mount doesn't really have a big bolt through it like the 92-95 bolts.
I don if you need any other bolts, ie mount to engine or mount to tranny etc, but you can find all the info from http://www.bernardiparts.com/SearchOptions.aspx if u are looking for the big bolts that go through the mounts you can use either a 97 civic or what ever car the engine came out of, they should be the same.
The bolts that bolt the flywheel to the engine are: 90011-PH3-000 you need 8
The bolts that bolt the clutch to the flywheel are: 90034-689-000 you need 6
The bolts that bolt the trans mission to the engine are: i cant find them, none of the part drawings have them. maby some one else could find them...
tattoo collector
04-04-2006 07:55 AM
trigun7469
12-31-2005 07:06 PM
90034689000, 90165sm4020, b18, bolt, bolts, civic, honda, hybridmathaolcom, motor, mount, tech, thread
