Ls swap into ek NEED HELP
I swapped a 97 ls motor into a 99 ek coupe and i needa know what engine harness i need to get for this thing to run.
i have an obd2 ls wiring harness alotta stuff dnt hook up.
do i need a sohc or si harness?
please help me out
please help me out
Re: Ls swap into ek NEED HELP
use your factory harness for the car, you may have to re-wire the distributor plug and the IACV plug, and get this conversion harness if you are running the ecu from the 97 LS http://rywire.com/store/obd2b-obd2a-...8b5c61c8b66994
