Help me!! fuel problem! d16 turbo.. wont start!
Re: Help me!! fuel problem! d16 turbo.. wont start!
did you check the main relay? usually that the culprit if your pump isnt even turning on. Its under your dash above the clutch pedal.
Did this no start condition suddenly happen to an otherwise running car, or did you do any mods before this happened?
92-95 Civics -- check fuses 31 (hood), 24 (dash), and 18 (dash).
96-00 Civics -- check fuses 44 (hood), 31 (dash), and 13 (dash).
Is the CEL ON? If so, are you able to pull a code? Do you also lack spark? Have you checked the important ground wire on the thermostat housing?
92redhatch
38
08-03-2006 04:51 PM
