no start
no start
it will start fine before driving, after stopping to get gas it wont start. checked main relay, coil igniter. flawless. checked for codes got solid cel. replaced with new ecu and same problem. has anyone had this problem. this is a 93 civic d15b7.
Re: no start
the sympton with the car goes as follows
- Tried 3 different main relays
- cranks fast just will not start when car is at operating temp
- tested spark with spark tester fine, also have tried different coils and ignitors
- Getting plenty of fuel you can smell it and hear the pump
- tried 2 different ecu's
- pop clutch it will struggle but it will start
Starts just fine cold but at operating temp when you shut it off and go to restart it the issue comes into play. Car also drives great no matter the temp if its at operating or not.
Re: no start
Does the CEL remain on steady with and without the service connector jumped? If so, have you cleaned and tightened the important ground wire attached to the thermostat housing? Another possibility is a bad ignition switch with the problem being the ON(III) position.
Re: no start
cel only comes on when jumped and have checked the ignition harness. have checked the tstat ground but havent cleaned it. will try
Re: no start
Did you run all of the continuity tests for the ON(III) position. Note that these tests must be done when the engine won't start. The ability to push start the engine suggests an intermittent ON(III) problem.
Re: no start
hey just to make sure on checking the continuity ON lll they all 3 have have to be checked at the same time correct
Re: no start
ignition switch tested fine. i did notice that the starter cut relay was buzzing. does anyone have a diagram fo testing this relay. the buzzing is a good sign but want to check before buying a part
Re: no start
When the engine won't start, you can still reliably push start the engine, right? If so, check whether the main relay fails to get battery voltage through the starter circuit on the BLU/WHT wire with the key in the ON(III) position.
