Installing rear sway bar on non factory sway bar'd eg
Hey guys, a friend recently gave me his stock em1 si sway bar for free. I went to honda and ordered the brackets/bushings and bolts to mount it to the subframe. I'm a bit confused how I'm supposed to mount the brackets though. Do I just drill and tap my own holes for the bolts?
Thanks in advance! BTW pictures would help a lot!
Re: Installing rear sway bar on non factory sway bar'd eg
In order to attach a rear sway on an eg, you need the LCAs off a 4dr EX, and im pretty sure that the EM1 sway will not fit on an EG hatch, or any 92-95. You need the sway off a 92-95 EX or aftermarket
why wouldn't it fit? Isn't it the same? I know EK contorl arms are longer but it should still bolt up right?
Oh and I already have blox lca's installed.
Well if you have aftermarket LCA, thats not an issue. They are both 13mm, but they are different part numbers. They have different curves in them. The 92-95 curves up, whereas the 99-00 has no curve.
OP, if you have an eg u need 94-01 integra, or 92-95 4dr ex lca's. or some aftermarket ones. you also need all their hardware, plus bolts to attach it to the subframe. the holes should be there but wont screw in; you need to bolt em up...
vtecvoodoo
12
04-10-2002 05:19 PM
