Idle & Tranny problem, pls help.
I don't know what's wrong with my car. I've talked to my friend who's a tech at Totoya. He came over and had a look at it but he couldn't figure out the problem. He drove the car but the problem only happens spontaneously.
Problems
-Lately been having weird idle. Even when engine is warmed up it idles at 1100-1200RPM only happens sometimes. Other time it idles fine.
-Idle drops to 600rpm (almost stalling out) and flutuates back up to 800rpm.
Bigger problem
-I will engage the clutch in first gear but the rpms drop drastically fast and doesn't grab the gear. AKA I can't ride the clutch to engage the gear. All it does is drop way below where it should be grabbing. I then throw it into 2nd gear to try to catch but it does the same thing.
-When this happens I rev the rpms really high to engage gear. 4000RPM - 5000RPM.
-This just happend recently as the problem is getting worse. I will be getting into 3rd gear and the gear will grab but then it will dis-engage and bog the car. Then catch the gear again.
What do I need to check? Is this a tranny problem, vacuum or air problem? =(
Problems
Bigger problem
Re: Idle & Tranny problem, pls help.
foo dats weird kuz i kinda hav da same thing 2 like my kar idles it goes p 2 2000rpm n drop dwn 2 900 rpm n goes up i think its da vacuum hose jst check dat n prolly ur synchros r bad
^ It's just a JDM D15b all stock. No CEL. However the cluster is swapped so I really don't know.
Update: Car just idled 1100RPM continuously, even after shutting down the car.
Can the idle itself alone be causing all these problems?
