Impossible idle problem
Ok ive checked everything related to my erratic idle it goes up and down nonstop. The iacv is good, the map sensor is good,no vaccum leaks, tps is good, i totally cleaned my throttle body. No cel, im out of ideas. Its a 92 4door civic auto trans d15b non vtec, any one have any ideas? Please help! Thanks
Re: Impossible idle problem
is it too low of an idle or too high of an idle?
if its too low of an idle being that you have an auto trans it can be that your trans is going out.
I'm Huge In Japan
https://honda-tech.com/forums/showth...light=end+idle
-- Also, if you've recently done work involving draining the coolant system, you likely have bubbles in the FITV/IACV coolant lines. Refer to your manual for bleeding instructions.
the white thing in the fast idle valve under the throttle body was loose. i screwed it in and it runs fine now thanks guys
