Overheating Problems
Old Aug 23, 2009 | 07:00 PM
Wakes4Fun's Avatar
Default Overheating Problems
After swapping motors in my car I started having problems with over heating so I changed my thermostat & fan switch. That didn't seem to help so I flushed it out and took the thermostat out temporarily. Now the car is running cool but I've noticed that where the fluid out of the rad. touches my paint or anything else in the engine bay it leaves a white residue?? Now I've checked my oil and it doesn't seem to be mixing with the oil so what the hell could it be??
Thanks
Will
BTW It's a 94 Hatch with a B16a swap
Old Aug 23, 2009 | 07:31 PM
jkalex05's Avatar
Default Re: Overheating Problems
Is the fan working properly? It might be that the fan isn't turning on when its supposed to and when you took out the thermostat it turned on automatically. Check that.
Are you replacing coolant? Any leak anywhere?
Old Aug 24, 2009 | 02:16 PM
Wakes4Fun's Avatar
The fan seems to be working properly and i did find a small coolant leak but I highly doubt it was the problem.
Old Aug 24, 2009 | 03:11 PM
forcefedferio's Avatar
you'd be surprised, it's not so much the fact of coolant leaking in volume as much as it is the system losing pressure. When your cooling system bleeds off pressure it will cause overheating.
Old Aug 24, 2009 | 03:32 PM
Arcitekt's Avatar
MOB Mentality
replace fan sensor and start using royal purple coolant.
4g4dcruisin
Aug 7, 2009 11:58 PM
BlkTegOn18s
Feb 23, 2009 05:15 PM
toyonda
Jan 26, 2009 06:06 AM
96_RHD_EK
21
May 1, 2008 08:11 AM
sivicstyle
May 29, 2004 07:18 AM
