Idling woes 99-00 em1
hello, searched forums and still no avail
problem: sometimes car starts at 2000 rpms on cold start, need to restart car to make it go back to normal. sometimes ill be driving, at a stoplight or when car is in neurtal rpm is about 1100. need to restart car to solve.
attempts: already tried cleaning IACV screen, it LOOKS clean, no dirt blockage. checked for vacuum leaks found none, tightened all bolts and clamps on air filter. cleaned MAP sensor with map sensor cleaner.
any other suggestions to help me withis prob? thanks
Re: Idling woes 99-00 em1
Is the CEL on?
When the idle is high, pull off the intake and use you finger to cover the port in the throttle body leading to the IACV. If the idle speed drops, try adjusting the idle speed:
ok for the idling screw, do i leave the car on when turning the screw or is the car off? also do i turn it left or right to lower idle? thanks
ibe2fly
31
11-21-2005 04:17 PM
