tachometer,odometer,gas and temp gauge dont work
Old 08-23-2009, 12:54 PM
jdmkris's Avatar
Default tachometer,odometer,gas and temp gauge dont work
i have a 95 civic dx with an lsvtec the tachometer,odometer,gas and temp gauge dont work but the back light to the cluster works fine..out of no where rpm needle and all other needles stopped working. hazard signals work on the cluster..but turning signals dont.I checked the fuses and they are fine.what may the problem be? thanks
Old 08-23-2009, 12:57 PM
VEGAN_EG's Avatar
Default Re: tachometer,odometer,gas and temp gauge dont work
bad cluster???
loose wires? check the wiring that plugs into it, try another cluster if you can
Old 08-23-2009, 01:02 PM
jdmkris's Avatar
ill see if i get another cluster tomorrow..checked the wires and they are fine
Old 09-10-2009, 07:48 AM
96f22b2's Avatar
i have the same problem now with my turbo crx.. rpm guage and turn sigs stopped working over night. hazerds work though.
Shane96teg
01-28-2013 04:10 PM
jdmsteveo05
12-31-2006 01:04 PM
bubbakrip
03-29-2006 09:37 PM
alexross
10-22-2004 11:28 PM
Quick Reply: tachometer,odometer,gas and temp gauge dont work
