1994 Honda Del Sol DOHC motor mount question
I have the 94 del sol that comes stock with the b16a3.
question is what motor mounts do i get for it?
Do i get the one that fits b series into eg or the ek?
one of mine ripped out from the ac and looking to replace all of it since its
getting old and taking alot of abuse.
Thanks ahead
Thanks ahead
Re: 1994 Honda Del Sol DOHC motor mount question
"Rick Rabies" has some I think, and he wasn't asking that much. PM him, he might still have some left.
Otherwise, you can fill old mounts with Window Weld to repair/stiffen then.
xshortx - don't hijack...
OP = 92-95 civic ----- DOOOOO EEEEETTTT
Or you could get polyurethane ones from any internet vendor. Poly bushings = stiffer = better throttle response and torque...
POLYURETHANE FTW111!!
naw really....
hasport makes some nice mounts too, but I'm not sure they make polyurethane bushings so they are spongy and not as fast. Polyurethane bushings are harder then OEM ones, so you feel more vibration from the motor inside the car... Your *** is massaged more, so it's nice, and the girls like it too....
naw really....
EDIT
xshortx - sorry, you are the original poster - you're not hijacking. The advice still stands, most of it anyways... the rest is for the ppl trying to hijack threads.
everyone else - don't post drunk
you can use any mounts from eg dc and of course del sol...the only b series mount you can use of the ek is the rear tranny mount...hopes this info helps look it up yourself at www.hasport.com
Seagull Management
You can't use an EK T-bracket on a Del Sol. Must be Del Sol VTEC or '94 - '01 Integra. As far as the rubber mounts go Civic, Del Sol or Integra doesn't matter, except for the drivers side rubber engine mount, which must be a black stamped unit with 2 holes, not the aluminum 3 hole version found on Integras, VX hatchbacks and some EX/Si models, and the front lower mounts (the rubber parts) must come from a civic or del sol.
or if you only wana spend a couple bucks you can fill your stock ones with polyurathane window seal. thats what i did. take a few says to set tough.
Seagull Management
Most people have a tendency to mean T bracket when they say rear mount. Either way you're wrong. Check the part numbers, '92 - '95 civic and '94 - '97 Del Sol Vtec (all del sol models actually) share the same part number. '96 - '00 civics are different.
well tendency is not here i clearly said rear MOUNT and on a b-series swap the rear mount is interchangeable on eg dc del sol and ek..thants the only mount off a ek you can use. part # may not be the same as you say but they are interchangeable..my boy is using a eg hasport rear tranny mount on his ek hatch and i had a ek hasport rear tranny mount on my eg 4 dr..so if your trying to tell me it doesnt fit tell it to our cars
xChrizcrozzx
08-21-2014 05:15 AM
j-villani
09-27-2012 01:27 PM
busted240
02-03-2008 09:38 PM
bluedelsol
06-03-2003 06:14 PM
