D16 MOTOR BUILD.. HELP!!
Re: D16 MOTOR BUILD.. HELP!!
Y8s not bad theres a lot of parts for the d series and the parts are cheaper cus everybodys trying to get parts for the b series. My d16y8 has a supercharger kamikaze headers 2.5" exhaust and AEM intake and i got 230 HP so you can get decent pull off a d sereis block. if you plan on going more then that rebuild the block and head before you put it in your car
i was thinking about justt buying a z6 block and putting a y8 head on it, i heard the y8 blocks arent good at oil flow
yea, go with the Z6, its tried and true. The slight difference in stock power is from the obd2 ecu but theres much more crap to deal with on obd2. (unless you planned on running obd1 anyway) but the Z6 is definitly a better motor and is much more reliable than the Y8.
I actually have an extra Z6 block sitting here if you are interested in buying it PM me and we can work out a price.
ya generally speaking the z6 has a sturdier block.
y8's are good too, but it is KEY to port and shim the oil pump from what i hear..
here's a thread on why it should be done:
https://honda-tech.com/forums/forced-induction-16/d16y8-oil-pump-do-i-need-port-shim-2346265/
this is how u do it:
http://www.turbod16.com/viewtopic.ph...t&sd=a&start=0
turbod16.com is a great site for specifically turbo'd d-series. you can find out everything u need to know by searching there and honda-tech..
i just bought a z6 block ready to be built, im OBD2, BUT just using the d16a6 oil pump so that it will work with my car since i still have a crank sensor
02-20-2004 12:36 PM
