Cranks but won't turnover, have spark/fuel
Ok. I'm going to make this short but thorough.
Car: 1993 Civic EX with a B18B1 swap
I'm very confused as to what could be causing this. This problem didn't start occurring until I got water in my engine bay.
Car cranks but won't turnover. I've swapped the injectors out, distributor, fuel pressure regulator, main relay, spark plugs, and fuel pump. Fresh grounds for the ECU on the thermostat housing/valve cover.
I tested the distributor out today to see if I had spark. It had spark. The motor reeks of fuel if you crank too much and the spark plugs obviously get saturated in gas.
No CELs. I've reset the ECU. I tested the main relay harness for power. Tested the ECU pins for the injectors/main relay and they omit power. I have power to the TPS/MAP sensors.
Any ideas?
UPDATE
Tested distributor
UPDATE:
New dizzy, wiring harness, injectors, pump, main relay, head gasket, ecu, fpr, tps, map, iacv.
Any ideas?
UPDATE
Tested distributor
Yes it was. I used team integra's walkthrough on Distributor testing..
http://www.team-integra.net/sections...ArticleID=1115
Checked out fine. 16.2 ohm and .8 ohm between said wiring/coil, 12V on both the blue/white black/ylw wires that run to the ICM.
Also pulled off the valve cover. Set crankshaft to TDC, checked camshafts, they are at TDC as well. Dead on timing.
Last thing on the list would be wires, but I don't know how because I tested spark and I see it.
http://www.youtube.com/watch?v=rrTJY...e=channel_page
@ :59
@ 1:20
@ 3:04 it really sounds like it wants to start
@ 3:40 a shitload of smoke
@ 4:07, 4:27 I really thought it was going to fire
@ :59
@ 1:20
Location: Japanese Domestic Mutt, aka JDM, Conn., U.S.A.
Re: Cranks but won't turnover, have spark/fuel
Cranking and turning over are the same thing! Do you mean that it cranks but does not fire?
Bumppp
Replaced fuses. Ran voltmeter on fuel injectors/pump. Pump primes, injectors receive power. Replaced FPR.
Did you put your dist. back on with the rotor shaft turned around 180 degrees from where it should be? How did you get the bay wet and how wet? Did a sudden flood come? Did it roll into a brook?
As far as the rotor is concerned, It is flat on one side...really is only one way to put it on.
Have you pulled a spark plug out and with it still connected, see if there is spark when you turn over?
It sounds like you did.
If so, then it has to be timing, if you're getting fuel. An engine needs fuel +spark+timing to run. Sounds like you have fuel and spark.
I had a bad crank position sensor in my dizzy that messed me up.
I am by no means trying to insult your intelligence, but did you check and double check the firing order?
Also, there's a fuse in the underdash fuse box that keeps the engine from starting when it's pulled. Did you check under there as well?
Firing order is dead on. From bottom left clockwise, 1342
I still continue to smell fuel if I crank for a set period of time. My plugs are saturated if I keep cranking. Doesn't make sense at all.
Well they're saturated and fouling because the injectors are pumping fuel into the cylinder and it's not being burnt.
So all you did was wash the bay.. Nothing else? And then it wouldnt crank.. Hmmnnn.
I still say it's a timing issue. Since you say the engine is timed correctly, then it has to be the Dizzy. Even though you checked it, something isnt right. Have you swapped dizzys with a known, working dizzy off a running car?
What color/quality is the spark at the plug?
And yes, if you keep trying to crank you just get gas all over the plugs and nothing will happen.
I had a similar problem with a 97EX and after we replaced everything, checked the timing blah blah blah we were going to have it hauled off. It sat over night, and started the next morning. Plugs were fouled.
I sprayed the tranny/block down with Carb cleaner and a hose. Bad mistake on my part. Then I d/c my injectors as a safe measure for some kids that were driving up and down my block, forgot about it the next day...cranked the car nonstop with them d/c and now I'm in the position I'm in. I swapped damn near everything electrical/fuel based and can't get it started.
Spark at the plugs should be bright white with only a very slight bluish tinge. The orangish/brownish color of the spark may indicate a weak coil.
The strong smell of fuel may also indicate that the cylinders are flooded, which can cause low compression. Pull the plugs and let the cylinders dry out. Also smell the oil on the dipstick. Does it smell strongly of gasoline? If so, consider replacing the engine oil.
Next test compression of the cylinders.
Also post pictures of the mechanical timing of the cam and crank at TDC1.
Ok, finally got the car started.
It kept choking up, so I kept having to jump it. Cranked it about 10 times and it finally started.
Drove it down the street and it was sputting like no other. I figure the plugs are probably fouled or something.
We'll see if it starts tomorrow morning.
