92 sedan passenger door
just bought a 1992 sedan with 140k with power steering and ac and clean title, which i thought was a pretty good deal. needs body work which is fine since its my second car. but the passenger door has been replaced with a non powered door(which i am not worried about) but the door doesnt line up right and there is no gap betwwen the end of the front and beginning of the rear door. is there a difference between the coupe and hatcback doors compared to the sedan? i tried the search but all it came up was headlights and corners.
Re: 92 sedan passenger door
yes, there is a huge difference. a Coupe/hatchback door would not even come close to fitting.
It sounds like you just need to do some adjustments with the mounting bolts, that's all.
and also, if you wanted to convert the non-power door to power everything will bolt up just like it should, they are the same door. parts can be found dirt cheap at a salvage yard, and takes around an hour to swap everything over.
camera obscura
02-10-2003 07:50 AM
