squeeking water pump...
so just recently iv been hearing a squeeking sound rite by my water pump or atleast by that area (most positive water pump tho)...does this mean its going bad...its an lsv motor by the way but it hasnt been overheating at all its just been squeeking when at idle...any inputs
Re: squeeking water pump...
well yah thats wat i meant..whining or squeeking watever....im pretty positive its not the alternator belt squeeking...i know the sound of the belts squeeking...
I know of a pretty experienced older gentleman that used to post at another Honda forum who said he had heard a "chirping sound when cold and a high pitched whistle when hot" coming from his water pump just before it failed. Typically it is a failure of the pump's bearings, which is often traceable to using non-OEM coolant. How long in miles and years has the water pump been there?
OEM coolant is silicate free or something like this. My experience with ordinary green Prestone and similar is a failed water pump. Many others attest to same. I have been using (as a now completed experiment) the orange Havoline Dexcool for the last seven years, with no problems. Dexcool packaging says it is "free of Silicate, Phosphate, Nitrite and Borate" and "meets or exceeds... Japanese car manufacturers' coolant requirements." If the OP has not been using either OEM or the orange Havoline Dexcool, then this is more evidence his water pump (bearings) are failing.
I've always grabbed whatever coolant is cheapest, and I guesstimate the mix (40-60%ish) and i've never had a problem. 88 toyota pickup, 91 civic, 88 crx, 95 supra, 06 wrx, 89 civic, 94 nsx, 94 civic... Just don't use tap water.
Oct 1997 -- new water pump with timing belt change as part of normal maintenance.
Apr 1999 -- failed water pump
July 2001 -- failed water pump
Nov 2002 switched to orange Havoline Dexcool, changing every two years (but I am switching to three years or so). No water pump problems since.
I think it was the anti-freeze I was using. I can't say this with a 100% certainty, but given my experiences and others' with this, I am sticking with either OEM coolant or the orange Havoline Dexcool.
i honostly dont kno how long the water pump has been there...but today after a drive home from work, i noticed a very little coolant leak that was dripping under the oil pan on the water pump side...so im guessing its going out...i mite just upgrade to a gsr/itr and timing belt upgrade since its a stock ls one on there...any ruff estimate on how much everything will cost...
Are you doing the labor yourself? Part estimates may be had at www.bkhondaparts.com , among other OEM part dealers online. Unless you have more info about the timing belt, replace it, the tensioner, the cam seal, the crank seal and of course the water pump. Also if you have no idea how old the coolant is or what type it is, I would drain it, flush it (repeated fill and drains), and replace it with OEM coolant or the orange Havoline Dexcool pre-mixed or mixed with distilled water only.
January 1999--Coolant reservoir was low; added a couple of cups of coolant.
March-April 1999--Heater had not been heating properly. Added another couple cups of coolant. Had water pump replaced. Heater worked fine forever afterwards.
January 2001--Added couple of cups of coolant.
July 12, 2001--While tires were being rotated on a rack at a repair shop, water pump was noted to be dripping some. Replacement of water pump was recommended.
July 25, 2001--Had new water pump installed.
So there were no sudden failures. I did not know enough back then to listen for noises from the water pump or think that a "couple cups" of coolant needed might be excessive. A little coolant being added each year is normal. Some is lost through normal operations. Also my Civic was in the northern U.S. during this period, which given the cold temperatures means one is a bit safer with a leaking water pump, especially about ten months of the year. In summer in places further south, I would not expect to be as safe.
