ls-vtec whp question
ok im building an all motor ls vtec the bottom end has endyn 11.5.1 compression pistons, eagle rods, eagle crank and im using a jdm b16 head ITR cams ITR intake mani with holley throttle body vibrant 4.1 header CTR dual vavle springs and retainers 2.5 exhaust carbon fiber intake 450cc injectors. what do you think my whp will be im hoping for 210whp but im not sure if i'll get it and i want to know if its even possible. also could i spray or is that compression way to high to be reliable?
let me know what you think i will be posting pics of my build soon.
ps it will be tuned on my hondata s200
Re: ls-vtec whp question
No offense but why in the world are you worried about hp right now? Build it Build it right make it reliable (if there really is a true reliable lsvtec) and get it dynoed. There is no way to tell over the computer what kind of hp you will have.
i know but with the set up i was wondering if someone had something similar i just wanted a ball park figure amd yes it will be dyno tuned for sure. its my daily driver so im hoping its relaible lol
well its gonna be going to the block is gonna go to the machine shop soon im excited i want to hit 13s na oh will 11.5.1 compression plus the higher compression 16 head will it be ok to run nos??
im not sure about that. They are 11.5 CR pistons for what motor? Because the factory CR rating on the pistons depends on what motor its supposed to go into, because different heads have different combustion chamber sizes. I'm not sure about running NOS, it has a tendency to burn up piston rings. Although you could get tuned to run NOS.
On the compression calculator, it should have about 12.09 CR with a B16 head, and 12.39 on a GSR head. 12.XX compression is high for the street. I'm not sure what kind of gas mileage you will get. Atleast your cams aren't too aggressive. I'm not sure about spraying, since I'm not a fan of it, but you will def need to get tuned to spray, with compression that high, or you will have detonation and maybe melt a piston.
it might last longer. Do you have ceramic coated pistons or nitrate coated rings for higher heat tolerance? And yes if its 11.5 for a LS then it will be at 12.XX on a VTEC head.
your the man thanks alot no they are not coated pistons im not worried bout gas mileage it cant be that bad lol i just dont wanna have to run race gas lol 93 is good for me i really want over 200whp i want 220 but i think ima get like 198 to 200 the more i look up the more i see like 200 might be more likely i may try t get CTR cams instead should i port and polish the head will it make a big difference cause its alot of money lol
P12 EG6
71
01-20-2009 06:56 PM
