CT: 2000 Ek w/Z6 help__?? -_-
Alright so i have 2000 EK hatch DX w/D17Y7, i have heard ridiculous amount of stories about SOHC Turbos..so that is what i am aiming for next, As of right now i have a full! 95 Z6 swap in the garage and i have the jumper harness for the p28 .. I have done research on the web, but im not clear exactly ..I'v heard that since i am running a 2000 obd2 harness w/o vtec ..i would have to wire vtec and that my distributor and injectors will not plug in!?!? so i thought of using the Y7 injectors and dizzy but people say i need a VTEC dizzy ...so im just confused ..can anyone help me out ???
Re: CT: 2000 Ek w/Z6 help__?? -_-
I believe u have to use a vtec dizzy. Look up the part number and see if there the same, if not order a dizzy jumper harness off passswordjdm.com its 40$ and is super convient. U will also have to wirre in injector plugs and alternator u can use ur obd2 alt but can't use obd2 injectors u must wire in the obd1plugs.
'96typeR
12
06-28-2011 08:24 AM
brixcivic
06-03-2010 09:10 PM
00, 96, civic, d17y7, distributor, dx, ek, honda, rebuilding, start, tech, trans, transmission, wiring, z6
