which b16?
which b16?
I REALLY want a del sol and after selling my teg im sure i wont get over 2.5k so i wanted to get a single cam sol and swap in a b16 over the summer (im not a professional lol) I do have some experiecne working on motors and hmotorsonline said its a complete change over b with stock motor mounts but i wanted to know if i could put any b16 into a 93-97 sol? And if theres a website with step by step rules can i get the link.
Thanks
Thanks
Re: which b16?
you can put any b series into a del sol and it'll mount right up. if you get the full swaps the only thing you might wanna get is a wire harness.
Re: which b16?
well is a wiring harness the same thing as a engine harness?
here's what the package comes with
B16A 88-91 (SiR I) Complete Change Over
Price: $ 1699.00 Plus shipping and handling.
Availability: Sold Out Till Mid April
- Motor
- Cable Tranny (Y1, S1, J1)
- ECU (PR3, PW0)
- Axles with Half Shaft
- Shift Linkage*
- Stock Motor Mounts*
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
- Motor
- ECU (PR3, PW0)
- Shift Linkage*
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
Re: which b16?
So this swap would work?
B16A 92-95 (SiR-II) Complete Change Over
Price: $ 2250.00 Plus shipping and handling
- Motor
- Hydraulic Tranny (S21, Y21)
- ECU (P30)
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Motor
- ECU (P30)
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
Re: which b16?
you want the SIRII swap with the hydro tranny, also you will use the stock harness and add wires as needed
here is what you need also you need to tell them you are putting it in a del sol so they can give you the right shift linkage
http://hmotorsonline.com/shop/sc2000...age&item=30005
Re: which b16?
and pay the extra $300 for the lsd tranny. it's worth it. otherwise you'll want it down the road and end up paying $1000 to buy and install the lsd. just my 2 cents
Re: which b16?
instead of one wheel drive wheel burnouts you can do two wheel burnouts.
better traction. it picks a wheel with less power and gives it more while still giving the other tire some too. or it picks the better gripping wheel i can't remember off the top of my head.
but i have a 95 DS with the SIR II and lsd and its good fun. no b18 but still fun.
gzes
25
12-19-2012 05:46 AM
